Construction | Slide parts ordered
A project log for Digibone
A digital instrument with all the flare of a trombone, with the power and flexibility of an MIDI instrument
craig-hissettCraig Hissett 04/04/2019 at 13:470 Comments
I've just put an order in for the following lengths of 20x20 aluminium extrusion:
500mm x 2
100mm x 4
This will give me the parts I need to:
Once the slide is built I should have a fully working slide-based MIDI controller :-)
Following that it will be the construction of the back frame.
I am contemplating changing the frame from a simple 2D section to a 3D box section, allowing me to mount a forward facing speaker for a more trombone-like output.
I could always add a secondary speaker at the back of the frame behind the main speaker for some interesting chorus-like effects or stereo output (playing harmonies, stereo delay etc).
