Build log 6- back flaps
A project log for Animatronic Iron Man MKIII suit
RFID tags in the gloves control shoulder rockets pods, hip pods, forearm missile, back flaps and wireless helmet.
jeromekeltyjeromekelty 04/23/2014 at 04:351 Comment
The back flaps were very straight forward to animate. The flaps were first held in place with tape in order to locate the hinges.
Hinges were constructed using brass rod and tube and they were epoxied to the back of the flaps. The hinges were then mounted to the back of the upper torso by drilling holes and using epoxy putty to bond them in place.
Control horns were mounted to the flaps and slots were cut in the upper back torso section so the control horns and connecting rods could fit through. The servos to move the back flaps were mounted to the inside of the upper back torso using high strength Velcro.
Finished!
betosantos1.personal wrote 04/23/2014 at 18:41 point
É possivel eu conseguir o circuito eletronico deste projeto?
betosantos.personal@hotmail.com
Agradeço desde já! Obrigado!!
