Ended up hot snotting to keep the webbing in the holes. The friction holding it in seems to wear off over time. The trick is not to hot snot anywhere the paw is. E6000 has been hanging in there for webbing on webbing. Tried to make fillets to lessen the chance of it peeling off. It wouldn't be removable if it was on rubber.
Finally worn down enough to put in the patches.
lion mclionhead
