SimpliBox IO is an universal USB IO
module with the following features:
• HID USB device – no
drivers needed
• 2 relay outputs 240V / 2A (NO, NC and COM)
2 opto isolated inputs 5...24VDC
• Status LEDs for any input
and output
• Open source firmware available
• Sample code
for Python (for example for Raspberry Pi) available
• Sample
code for C++ for Windows & Linux PC available
• No
additional power supply needed
• Comes in kit form (THT parts
only)
• Fits perfect in an optional 3 module cab rail
enclosure
How it works:
SimpliBox don't needs USB drivers
because of HID technology. It's very easy to combine it with various
hosts, different operating systems (Linux, Windows...) and platforms
(PC, Laptops, Raspberry Pi, Beagle Bone...)
It based on an ATMEL ATTINY45
microcontroller which runs a firmware with V-USB stack. We have only
5 free IO pins, but we need 6 pins for 2 outputs, 2 inputs and 2 USB
GPIOs. The solution is the internal ADC. We measure the voltage of an
internal voltage divider. Single resistors are bypassed by the
phototransistors of the optocoupler. This is the simple solution for
our problem with the pin count.
Please take a look to our
website for more information. We provide the schematics, firmware,
sample code in Python, C++, C# and also a detailed construction manual
there.
davedarko
Julian Calaby
ACROBOTIC Industries
David Tillemans
