Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Courses Tutorials Events Hackerspaces Profiles Hackaday.com Tindie Marketplace
Sign up Log in
Wheelastic - Image on Wheel LED mod
RGB LED strips display images on rotating bike wheel which can be controlled using a mobile app over wifi
thiagesh Dthiagesh D
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1 comments
361 followers
  • Description
  • Details
  • Files 0
  • Components 5
    • View all
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 1
View Gallery
359
1
361
3
Team (1)
  • thiagesh Dthiagesh D
Join this project's team
completed project
SPARK PHOTON rgb led HALL EFFECT SENSOR Wheel
This project was created on 12/20/2015 and last updated 7 years ago.
Description
Image Simulation on wheel using Spark Photon and programmable RGB Led strips.
Speed of the wheel is found using magnetic sensors.
Fixed magnet is placed outside the wheel.
Two Hall Effect sensors are placed at the rims of the wheel, so that they can sense the magnet placed outside while the wheel is rotating.
Two programmable RGB Led strips are placed as shown in the image, and based on the sensor reading, and the time between the magnetic contact, the angle of the wheel is calculated.
With the angle of the wheel known, LED's are controlled accordingly to display the requested image or pattern.
An android app is written which invokes photon's cloud functions for turning on,off, switch images etc.
Images are transferred over TCP from the android app to the photon in the form of 50*50 pixel matrix.
This pixel matrix is used by the photon to turn on the LED's accordingly.
Components
  • 1 × particle photon
  • 1 × programmable RGB LED
  • 4 × AA Rechargeable battery
  • 2 × Hall effect sensor
  • 1 × Magnet
Project Logs
Collapse
  • Video of the project in action
    thiagesh D • 12/21/2015 at 16:50 • 0 comments
View project log
Log In/Sign up to comment
Sign up with Github
OR
cschrisstarke wrote 01/08/2016 at 20:58 • point
Fantastic project I've been wanting to do something similar for a while now,  will you be realising a schematic and code? Would be awesome to replicate this!
The 2018 Hackaday Prize
An interactive, wireless 16×16 pixel canvas that displays your images and animations.
Project Owner Contributor
Pixel8 | LED Pixel Art
ACROBOTIC IndustriesACROBOTIC Industries
The 2016 Hackaday Prize
A small gadget that reminds you to bring an umbrella
MyForecast
jareklupinskijareklupinski
LED Matrix using Pixel Blaze
LED Box
morganmorgan
Timepieces built using vintage HDSP-2000 LED displays
Retro Time: dot matrix LED clocks
Patrick HickeyPatrick Hickey
Going up?
© 2023 Hackaday
Yes, delete it Cancel
You are about to report the project "Wheelastic - Image on Wheel LED mod", please tell us the reason.
Send message
Remove Member
