BMS Module: can it be put in an empty 18650 cell ?
A project log for Universal Battery Module
The goal is to create a bulletproof 18650 based battery solution applicable to a wide variety of tasks; solar, utility vehicles, EVs, boats.
michel-kuenemannMichel Kuenemann 03/23/2016 at 18:370 Comments
This sketch shows the main components of the BMS module put on a 18650 cell outline:
It seems possible to insert the BMS module in an empty 18650 cell. This opens new perspectives !
To be confirmed, anyhow.
The Module could look like this :
