Test mode
A project log for KSP Gegi
Kerbal Space Program physical status and control panel
maciej-witkowiakMaciej Witkowiak 01/10/2016 at 23:290 Comments
I have added test mode to the controller. Until 'R'(eset) command is received from Python kRPC script the controller will just react to the events on its own.
The four Lights/Gear/RCS/SAS switches will turn red/green LEDs on and off.
Throttle and Time Warp potentiometers will drive the two analog voltmeter displays.
