Testing tones
A project log for BEEP communicator
Because all robots should beep
MattFMattF 03/18/2018 at 01:150 Comments
Before I start coding I'll need to come up with some audio samples so I can create a set of tones to use as data symbols. I'd like to make it sound robotic and synthesizer tools are a good way to test what works.
I've been looking at https://onlinesequencer.net/ (no affiliation) mainly because it's online and I can save the output.
So far I've recognised that high-ish frequencies sounds good, and that using a musical key makes any combinations sound too... musical.
Example audio so far http://onlinesequencer.net/763546
