Project started!
A project log for Tiny Time-of-Flight Plasma Theremin: the Plasmino
Music evolved! The Theremin for the 21st Century: Plasma speaker, MIDI output, Lasers!
davidDavid 08/31/2018 at 10:120 Comments
OK, I've stripped down a dual-arc lighter, and reverse engineered the circuit.
Seems to be just 2 mosfets, a few resistors and the pulse generator/LiPo charger that I won't be needing at this stage.
I've started coding a Arduino Nano clone to generate the note, as done previously here:
http://ultrakeet.com.au/write-ups/modulated-arc-lighter
After that, I'll add in VL53LOX TOF sensor support.
