3D printed robotic arm
This is a project inspired by @andrias, We will try to print it and later edit the design.
-This project is for learning how to deal with real 3D design. -How to control the kinematics of this design. - try to tacle the problems facing the original design& innovate more effective designs.
Today I started to:
- learn file extension types .ipt and .dwg
- downloaded autocad 2016 to view the robot design and got licensed.
- couldn't open because I needed inventor to view the parts and assembly files.
- got with @sai and sat a meeting to discuss our target
- viewed the forearm design with a360 online viewer and measured the dimensions.
- ordered the 3D to be printed (will decide tomorrow)
To do:
- get inventor, view the design, try to readapt the design.
- find other 3D printers able to get the original design.
- order the ball bearings, motors and nuts.
- keep track of the whole project.
Today,
We have installed inventor 2016 to our
Windows pcs so that we can view the design.
- we started reading and listening to Tutorials describing the main features of inventor 2016.
We set the target to reduce the current design to 80% of it's size now.
-Regarding screws and motors we will maintain them as the original design was too heavy to be powered solely by Nema11 and Nema 17.
- our next move is to keep learning about inventor and try to reduce the size of the design with maintaining the same size for the motors..
-another approach is to look for a bigger 3D printer that can print the original design with lighter materials.
3rd jan (Happy new Year 🎉🎉🎉🎉 Malik
I have completed the Inventor tutorial and heading towards editing the master design..
My plan is to edit the base items first and print them.. Then evaluate
End.
10-1-2016
since there were a lot of problems in dealing with the x0.8 derived version of the original design in inventor, I had to think of another solution.
this solution is to create the NEma17 hole dimensions multiplied by the factor 1.25 so that when a 0.8 model is derived the dimension return back to the actual Nema dimensions.
the was another problem with the gears offset due to the change in the shaft hole.
I dealt with this problem by changing the screw joint locations by shifting the hole extrusion to the right by 0.224mm and upwards by 3.218mm.
I am to check the design and create assembly file.
I hold up the 3D print order till I am sure about the design.
the new dimensions and the assymply file of the new x1.25 solution will be up soon.
11-1-2016
today I tested all parts of the first link and I made a lot of modifications in the design so that gears will fit the profiles and pins of the Nema17 will be in place.
I uploaded the new design and the assimbly file.
base segment- print1.stl
Microsoft Trust UI Provider - Certificate Trust Link - 1.21 MB - 01/14/2016 at 09:08
Download
arm geared- print1.stl
Microsoft Trust UI Provider - Certificate Trust Link - 253.50 kB - 01/14/2016 at 09:08
Download
arm gearless print1.stl
Microsoft Trust UI Provider - Certificate Trust Link - 214.44 kB - 01/14/2016 at 09:08
Download
gear-print1.stl
Microsoft Trust UI Provider - Certificate Trust Link - 100.47 kB - 01/14/2016 at 09:08
Download
arm geared- print1.ipt
ipt - 617.50 kB - 01/11/2016 at 12:57
Download
View all 15 files
  • creating x1.25 model
    Abd-el-rhman01/10/2016 at 15:10 0 comments
  • 3D printed robotic arm- dairy
    Abd-el-rhman01/04/2016 at 00:38 0 comments
    Today I started to:
    To do:
    Today,
    End.
    4th jan
    today I successfully edited the motor extrusion and uploaded the scaled base-segment.ipt file and the base with the Nema17 motor.iam file here.
    end
View all 2 project logs
