Photosensor
A project log for Low-resolution scanner for cheap data input
Or "let's revive the idea of the punched cards" for our kids' delight, but without the holes
yann-guidon-ygdesYann Guidon / YGDES • 04/21/2017 at 22:05•2 Comments
I just got a few CNY70.
Unfortunately they are a bit too large... 6mm instead of 5mm wide, so I can't use regular 5mm paper...
I still have to see what I can do with the BPW34.
If I can find them in my workshop, since I got them before the renovation...
Morning.Star wrote 04/22/2017 at 01:00 • point
Why dont you try LEDs? They behave as photodiodes. You'll need an amplifier to interface to them but they are essentially the same thing. Superbright reds are the most responsive. :-)
I've tried using 2.7v SMD LED chips, they work as well if you want a *really* small sensor array.
Also, Copper Oxide III (red) is photo sensitive and changes resistance in response to heat and light. ;-)
Yann Guidon / YGDES wrote 04/22/2017 at 07:23 • point
BPW34 would be the solution ;-)
