Technical data sheet:
External dimensions: X475mm Y430mm Z570mm
Working dimensions: X200mm Y200mm Z280mm
Resolution: 100micron
Extruder: E3D V6 Nozzle 0.4mm
Electronics: Arduino Mega 2560 + RAMPS 1.4 - Full Graphics Display Driver A4988 + SD
Firmware: Marlin 1.1
Mechanics: Stepper Motors NEMA 17, belt drive GT2, rods and bearings diameter 12mm
Structure: Frame in aluminum profiles 30x30mm + molded ABS
Features: heated plate, LED lighting, WebCam, print from SD, 9 points Auto Bed Leveling, Milling head for PCB, 550W ATX power supply with overload protection.
