Hardware - PCB Design
A project log for Automatic Self Cleaning Filter (Liquid)
Low Cost & Automated,using Atmega328P (Arduino) as it's brain. Controls Solenoid valve and DC Motor, by monitoring pressure inside.
amar-potdarAmar Potdar 02/24/2016 at 19:430 Comments
Diptrace is really a best tool for Schematics and PCB designing. I really recommend you to use it.
Once schematics is drafted and tested (using 123Dcircuits), it was quit easy to design the PCB.
I pre-decided about the placement of the components, by considering ease of use, ease of routing, minimum noise.
Hardware Placement
PCB will be Single Layer & Homemade, baked at college lab.
PCB design with DipTrace isn't a tough task.
Following are the images, to walk you through.
Top View
PCB 3D View
Home baked PCB etching.
- Single Layer
- etched using Layout photo print + Iron + Copper Clad + PCB etchantFeCl3
Home baked Single Layer PCB
