Errors from Wunderground API?
A project log for Sprinkler System Water Conservation
This project uses weather API's to determine if significant rain has fallen, or is forecast, and if so disables the sprinkler system.
chrisChris 04/06/2018 at 07:230 Comments
Currently the program has very simplistic error handling which makes sure the system is left in an 'on' state and goes back to sleep if any error occurs.
I am suspicious that the Wunderground API might be the source of some errors and have written a Python test program on my Raspberry Pi to call the API and record any errors that occur. Results from this can then be used to improve error handling, perhaps by querying an alternate PWS if the primary returns an error.
