Electrical water capacitor
I invented a device to generate electricity free but unfortunately did not allow me to hold the necessary tests because of the harsh conditions it in my
Name of the device and the idea of water-intensive work is based on the creation of artificial water whirlwind spin around 5000 rpm between two identical with exposing the water to pulses of high voltage in stages after the start of electric charges out in large quantities with the knowledge that the experimental model has succeeded and this is a picture of the device
Zevion wrote 06/13/2014 at 20:44 point
Basiclly you are making h20 genertor, your traspped hygrogen is your power
dave.m.mcdonough wrote 04/30/2014 at 14:45 point
I don't knowledge of working and difficult read without punctuation plus what do
