Using the parts obtained from tearing down a Da Vinvi Jr 3D printer, I will be creating a conversion kit.
The Y axis and frame are already modeled and parts are being printed and tested now. The goal here is to make a more stable capable printer from the parts, I will use as much as possible from the donor printer.
The only parts that need to be purchased is a lot of M4 10mm bolts and M4 nuts. I have opted for GT2 6mm belts and pulleys (20T), a ramps 1.4 controller and a reprap LCD.
Finaly got the x axis mount finished, it's a bit bulkier than I wanted but I have decided to use the extruder from the Da Vinci jr as well as it's x carriage thus the rail offset.
Elliot
Myles Eftos
Ted
Nikolai Ovesen
