reentry operations
A project log for single stage to orbit robotic space plane
single stage to orbit home built space plane multi configurable morphing wing lifting body autonomous robotic or manned
starlordstarlord 04/19/2018 at 03:500 Comments
here's a couple of pics showing the black raven on reentry the first one shows dragging a balute  basically a large high temp reinforced balloon that's inflated before reentry creating more aerodynamic drag the second represents skip reentry a type of airo braking technique where you bounce or skip off the atmosphere in stages to reduce heat build up I would like to combine both to try to get the coolest reentry as possible
