How to create a Moirè pattern
A project log for Schlieren-Videography
With this project I want to show you how you can make Schlieren-Videography at home. To do so we will use the Moiré-effect.
jana-marieJana Marie 02/11/2016 at 19:080 Comments
Just a quick idea of how to create a Moiré pattern using Inkscape.
  1. Open a new file ( DIN A4 or what is your standard size)
  2. Draw a square all over the outlines of the new file
  3. Set it to no stroke, go to fill and set the color to black
  4. Click on "pattern" and on "stripes 1:1"
  5. Now there should the a stripe-patter
In the upper left corner you can see a square, a circle and a "x"
With the square you can change the size of the stripes, with the circle the rotation and with the "x" you can move it. Just click on the symbol of your desire and drag it around to change/move the pattern.
