Just a quick update,
Linear Regulator
I looked at changing to a switch mode but after running some thermal simulations using the tools provided by the maker of some of the switching regulators I looked at predicted high temperatures. So for cost and convenience I'm keeping with the linear but am decreasing the input voltage from 9-12V to 6-9V. So far with 3 of the 4 cores disabled and radio enabled with a 6V PSU the SOC Doesn't read above 50 Degrees under stress. A great improvement.
Kersing Packet Forwarder
I still haven't been able to figure out why the packet forwarder is segfaulting when it goes to do a transmission, However I have now had the parts to build my second one so I can use that as a development one for now. Currently I have been using Ubuntu 16.04 with 4.11
I'm going to try with Debian Stretch which is the same OS that the RPi uses and we'll see if that works.
Ryan Walmsley
