DRONI SAME70Pi / 1.ELECTRONICS / PCB TOP DESIGN (Update)
A project log for Open Source All-In Drone-Droni SAME70Pi (Kopernik)
Yet another open source platform for drones, but this one is fully integrated and uses the SAME70@300Mhz x2 + a Pi Compute Module
laetitia-belLaetitia BEL 03/18/2018 at 19:580 Comments
I took into account the dimensions of all the sensors, sockets, arms,...
The initial view is slightly modified.
I moved a little fast on the PCB to have an initial version to make some iterations and verifications in parallel.
Il will give more details about the angles of the arms in another Log.
I just finished the first draw of the PCB TOP that handles the computation and the communication.
The final dimensions will be 100x200mm.
