DRONI SAME70Pi / 1.ELECTRONICS / PCB BOTTOM DESIGN (Update)
A project log for Open Source All-In Drone-Droni SAME70Pi (Kopernik)
Yet another open source platform for drones, but this one is fully integrated and uses the SAME70@300Mhz x2 + a Pi Compute Module
laetitia-belLaetitia BEL 03/20/2018 at 11:400 Comments
Here is the PCB BOTTOM that handles the power distribution.
It has a current sensor, a buzzer, a bunch of DC converters and connectors, and the fixations of the Pi CAM!
Th
I sent them to manufacturing with the TOP PCB, hope getting them before this weekend to start the assembly :)
I distributed the +11V1 directly.
Located in the top layer of the Cu.
The 0V of the LiPo is also distributed directly to avoid short cuts of a faulty isolation.
It is located in the bottom layer of the Cu.
The ESCs and LiPo are connected to the solder pads.
