DRONI SAME70Pi / 1.ELECTRONICS / PCB BOTTOM POWER DISTRIBUTION
A project log for Open Source All-In Drone-Droni SAME70Pi (Kopernik)
Yet another open source platform for drones, but this one is fully integrated and uses the SAME70@300Mhz x2 + a Pi Compute Module
laetitia-belLaetitia BEL 03/21/2018 at 00:040 Comments
The 5V0 voltage provided by the PCB BOTTOM is behind a filter.
The PCB BOTTOM provides 4x5V0.
There are multiple DC converters due to current limitation for each.
The PCB bottom provides the voltage to the motors.
It has a current sensors using a 0.001 ohm resistor with INA aplifier.
It provides the voltage of the 3cells of the LiPo to the PCB TOP.
