DRONI SAME70Pi / 1.ELECTRONICS / IMU SENS
A project log for Open Source All-In Drone-Droni SAME70Pi (Kopernik)
Yet another open source platform for drones, but this one is fully integrated and uses the SAME70@300Mhz x2 + a Pi Compute Module
laetitia-belLaetitia BEL 03/21/2018 at 18:350 Comments
This small piece of beauty is the graal of the project.
A full redundant 3xIMU + baros.
Quite small, it uses dumpers to get fixed on the TOP PCB of the drone.
We keep a little delta between the two holes of fixation 2mm Y axis, and 3mm X axis. The reason is to have a small stress to keep the equilibrium of the IMU SENS.
I use the 2xBMI160:
2xLSM9DS1:
2xLSM6DS33:
Finally two barometers and temperature sensors:
