Hackaday.io Hackaday.io
Sign up Log in
ESP8266-07 Breakout
A breadboard friendley Breakout for ESP8266-07 modules with some extra functions.
jan-bJan B.
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.8k views
2 comments
10 followers
  • Description
  • Details
  • Files 0
  • Components 12
    • View all
  • Logs 3
    • View all
  • Instructions 0
  • Discussion 2
View Gallery
1.8k
2
10
7
Team (1)
  • jan-bJan B.
Join this project's team
completed project
hardware
ESP8266 breakout BREADBOARD
This project is submitted for
  • Hackaday.com Tip Line
This project was created on 01/03/2016 and last updated 11 years ago.
Description
A ESP8266-07 Breakout for Breadboards made with KiCAD. Features: - Onboard 3.3V regulator - can work with TTL Serial - Reset and Programm Mode directley over the Serial header (based on: <a href="http://nerdralph.blogspot.de/2015/04/zero-wire-auto-reset-for-esp8266arduino.html" target="_blank">http://nerdralph.blogspot.de/2015/04/zero-wire-auto-reset-for-esp8266arduino.html</a>) - Voltage divider for ADC with max. 10V - Reset Button and Pin Header to enter Programm mode manually - on board LED on GPIO4 - Size: 50x32mm Download files : <a href="https://github.com/do9jhb/ESP07-Breakout" target="_blank">https://github.com/do9jhb/ESP07-Breakout</a>
Components
  • 1 × ESP8266-07
  • 1 × AMS1117-3.3V 3,3V LDO
  • 1 × Push Button
  • 1 × 3V3 Zener Diode
  • 1 × 2mm LED
View all 12 components
Project Logs
Collapse
  • Please Share your Experiences!
    Jan B. • 03/11/2016 at 15:58 • 0 comments
    When someone has built the Breakout, please share your experiences in the Comments, so I can improve it.
    Thank you!
  • It works!!
    Jan B. • 01/10/2016 at 12:51 • 0 comments
    After some issues with the Auto-Reset Circuit, it now works very well :)
    And so its looks in real :
    Here are the Layout files :
  • Schematic and PCB finished
    Jan B. • 01/04/2016 at 11:51 • 0 comments
    I have finished the PCB and the Schematic. The next days I will try to etch a PCB and build one.
    Here the Schematic:
View all 3 project logs
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Jan B. wrote 03/23/2016 at 19:59 • point
Thank you ;)
Yes I know that putting parts under the antenna is not the best solution, but I did not have so much space on the PCB and I thought that the best RF emission is not the main criteria for a breakout board...
And yes it works :)
Elliot Williams wrote 03/22/2016 at 09:05 • point
Great looking breakout.
My only critique is that the antenna part of the module should probably be as far from any metal parts as possible -- ground planes and components on the underside might influence the antenna / propagation.  Of course, if it works, it works.  :)
Various PCBs in location pin shape with a LED to guide the way and they are #not_a_badge
Project Owner Contributor
You Are Here
magicwolfiMagicWolfi
A compatible cheap and fully working Arduino board with a lots of traces and schematics. This is one I want for my projects.
I Made My own ARDUINO Uno Board
electroboyElectroBoy
Yep, a Nano with c type and compatible drivers is what I want for my projects. Get it now on PCBWAY the clone board
My own Arduino Nano Microcontroller board
lithium-ionLithium ION
My variation of the geeky Christmas decoration made out of PCB
PCB Christmas Tree
olekOlek
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "ESP8266-07 Breakout", please tell us the reason.
Send message
Remove Member
