close-circle
Merging projects
A project log for Lys Bright
A solar powered bright light
Ole Andreas UtstumoOle Andreas Utstumo 01/11/2017 at 15:280 Comments
I'm merging this project with Lys for the moment, as Lys and Lys Bright are identical, set apart for the LEDs themselves. Go here:
https://hackaday.io/project/11327-lys
If you just want white light at night, simply use white LEDs on the board and leave the ESP8266 wifi module out.
