Spent some extra time on the outer acrylic enclosure design - all the intake is on top, and the exhaust vents have been extensively restyled with a nice wave motif.
Laser cut from 1/8" acrylic.
Also added a fan shroud to prevent internal air recirculation from the heatsink. The 80mm fan sits directly on top of this (spaced with rubber washers)
Yann Ramin
