Bluetooth LE controller board firmware
01/21/2016 at 16:44 • 0 commentsFirmware for the Bluetooth LE board is now available on GitHub: http://github.com/theatrus/ledbrick
PWM setting, fan and temperature monitoring are both supported, with a fan-off failsafe. Temperature fail-safe and fan-spin-down is coming soon.
I'm also working on the BLE central controller, running on an RPi. Updates on that soon.
Acrylic case
01/21/2016 at 16:38 • 0 commentsSpent some extra time on the outer acrylic enclosure design - all the intake is on top, and the exhaust vents have been extensively restyled with a nice wave motif.
Laser cut from 1/8" acrylic.
Also added a fan shroud to prevent internal air recirculation from the heatsink. The 80mm fan sits directly on top of this (spaced with rubber washers)
Yann Ramin
