Sprouting Peppers
A project log for Indoor/Outdoor GrowBot
This is an opensource, modular garden system designed specifically for automation, IoT monitoring and remote control.
ProgressTHProgressTH 01/12/2016 at 14:380 Comments
January 12, 2016 | ProgressTH | Sprouting Peppers
It is actually not that hard to get most things to sprout, least of all peppers. The real test will be vegetation growth (skinny, tall plants are less desirable than full plants that grow outward as well as upward), as well as flowering and the production of peppers.
If this 30W 6500K white LED floodlight doesn't do the trick, another may be added (the original design calls for two and there is space for it to be mounted in the frame) and if that doesn't work, another type of light will have to be tested.
An aquaponic component is to be added soon too. If not, these sprouts will have to be put into proper soil and maybe different containers.
Follow ProgressTH.org on Facebook here or on Twitter here.
