DIY 3D Tilt Sensor
Bluetooth HID controller cube
tamberg wrote 04/30/2014 at 06:48 point
Hi Eric, the aluminium ball together with (at least) two nails acts like a switch, connecting a single pin of the Bluetooth module to ground. Each corner of the octahedron (and therefore each side of the cube) has one such switch, i.e. the cube sends one key per side.
Eric Evenchick wrote 04/30/2014 at 05:29 point
I get the Bluetooth part, but how does this thing measure tilt?
