Single-port USB Hub
A project log for Tote Zero
Affordable quadruped robot powered by a Pi Zero
deʃhipudeʃhipu 01/25/2016 at 21:361 Comment
In order to make working on the robot a little bit easier, I added a small USB hub that I had lying around, with a cheap WiFi card soldered to it. This way I have access to the board and still can use a single USB port for, say, a webcam.
Otherwise the progress has been slow. I adjusted and trimmed the servos, so that the robot can stand in the "zero" position, but I still haven't tested the inverse kinematics or walking code.
Craig Hissett wrote 01/26/2016 at 11:34 point
That's a great little addition!
