Motor layout for Y6
A project log for Multicopter Y6 Drone and GoPro Gimbal
Large multirotor drone Y6 frame for a two axis gimbal and small camera.
richard-hogbenRichard Hogben 01/05/2016 at 16:530 Comments
All motors are spinning clockwise, but 2, 4, and 6 are mounted upside down. When viewed from above they are rotating counterclockwise. This means all ESCs should be wired the same way.
All propellers should be installed text facing up and match the rotation of the motors when viewed from above.
