Install gimbal and wire gimbal controller
A project log for Multicopter Y6 Drone and GoPro Gimbal
Large multirotor drone Y6 frame for a two axis gimbal and small camera.
richard-hogbenRichard Hogben 01/14/2016 at 00:420 Comments
Gimbal went on ok.
Added pins and connected the IMU to the gimbal controller. This will mount below the body and have its own battery.
I flashed the controller with http://sourceforge.net/projects/brushless-gimbal-brugi/ I had to drop to Arduino version 1.0.5 for the sketch to compile correctly.
