Learning Fritzing
A project log for MQTT WiFi controlled mains halogen dimmer
MQTT WiFi controlled mains halogen dimmer that can be controlled by rotary controller or from home automation (OpenHab) by PIC and ESP8266
Marc SpoorendonkMarc Spoorendonk 02/07/2016 at 19:570 Comments
Learning how to use Fritzing in order to create a small perfboard to test the high-voltage part on the 300W halogen lamp.
