Mains part built. Now testing.
A project log for MQTT WiFi controlled mains halogen dimmer
MQTT WiFi controlled mains halogen dimmer that can be controlled by rotary controller or from home automation (OpenHab) by PIC and ESP8266
marc-spoorendonkMarc Spoorendonk 02/10/2016 at 22:220 Comments
The mains part with the triac is now built on perfboard. Works fine. A small reallife test showed that it also works on the 300W halogen transformer. Had to pull an extra nullwire as it wasn't present at this location.
