Finished product
A project log for Lapel Gears
Decorative gears for your lapel, or anywhere else
jedifixJediFix 01/17/2016 at 23:030 Comments
Everything (except the backing) was sanded, primed with black primer, the center gear was then painted with Krylon Antique Brass spray paint and the three small gears were painted with a few coats each with Krylon metallic paint pens. All the gears were then sealed with a Krylon matte finish clear coat (no, I don't work for Krylon, it is just what they had when I want paint shopping).
I had picked up some XTC-3D filler, but I did not have the time to use it before I needed these for the party.
The backing fit perfectly under the lapel of the frock coat I had rented, I used some of the extra gears I had printed in silver filament to make some last minute cufflinks (not pictured).
The lapel gears worked great all not, I only bumped one off all night and noticed right away that I did. They turned perfectly against the fabric of the coat and they were a big hit. I am really happy with how this turned out and I give big Thanks to the projects that inspired me and the designer of the gears!
