this type of keyboard can be used
03/26/2016 at 16:39 • 0 commentsthis device can be used or if you can buy a touch screen or if you have a tablet than you can use it as per the user just make a SE tion for keyboard and insert in it
the CPU mounting on DESK so this will be the hardware section
03/23/2016 at 02:19 • 0 commentsthis will be the hardware section as the CPU should be mounted there beneath the desk as the idea to show no wires and a future desktop or say desktop is there and cover it with extra wooden panel
the front USB ports
03/23/2016 at 02:14 • 0 commentsas mention earlier the USB ports will be in front of the user so this is the answer to that
how speaker will be installed in table
03/23/2016 at 02:09 • 0 commentsthis shows how I want to install the speakers in the table plz see I have written in the table by cutting small section for speakers and when computerr is switched on than all the desk comes alive
the keyboard and mouse
03/22/2016 at 16:19 • 0 commentsthis is the concept but I want the a screen having virtual keyboard on table and screen can also use as a mouse as having a touch screen will be expensive than this or if this is expensive than a touch screen with virtual keyboard
screen movement using linear actuator
03/22/2016 at 15:55 • 1 comment
inboxsahil.sahajpal
