Strike Ring (Primary Protection)
A project log for Tesla Coil
Medium Sized 22" Tesla Coil, currently standard, but working on conversion too solid state so it can be musical.
leo-mahdessianLeo Mahdessian 07/19/2016 at 03:220 Comments
Not much to say about the strike ring. It was constructed from 1/4 inch copper water pipe with 4 elbow joints that were sweated together. It was directly grounded to the bottom of the secondary coil. Mounted it to the base using wood blocks to elevate it above the primary coil.
The wood blocks had a piece of PVC pipe glued to the top that the strike ring could snap into. The photo below shows the sweated strike ring.
The photo below shows the mounting blocks before the strike ring was installed.
