Projector bubs need a LOT of lumens as per this article https://projectingarea.com/lux-vs-lumens-projector/ unfortunately LEDs just can't output that many lumens. I mean they can but you will have to use a 200w or even higher wattage to match the original bulb and you have to deal with all that heat. Also the wave lengths of LEDs are not the same as high discharge lamps. Just my two cents
I research a lot on projectors and I wanted to gather all the information about it. For this purpose I have a website too where I review all the projectors. https://projectorspoint.com/
