Cooling the Raspberry PI 3 's
A project log for Watchdog Security Camera Robot
Solar charges, Open build, affordable, watch and report or community presence robot.
josh-starnesJosh Starnes 03/22/2018 at 20:031 Comment
The Pi Board before the heat sinks
After applying 5 aluminum heat sinks. I used thermal pad that is similar to a putty to stick them on. the main processor has 4 of the 10 x 10mm heat sinks. the smaller chip which I believe is the ram only has one.
PointyOintment wrote 07/16/2018 at 06:58 point
The smaller chip is the USB hub and Ethernet adapter. The ram is integrated into the main chip along with the CPU and GPU, which is why it's called a System on Chip (SoC).
