power line filter
A project log for BluBEAM - a scanning laser microscope
Imaging at micrometer resolution using a Blu-ray drive
andreasbetzandreas.betz 02/11/2016 at 18:020 Comments
The last board I made is a filter for the power supply feeding the previous boards. As with any electrical project it's vital that we have a clean power supply, and in particular we want to avoid burning our lasers.
I'm using mostly big through hole components here, following this schematic:
And here is the finished board:
The big question of course now is whether it actually filters and how much. I don't have access to a network analyzer that goes to very low frequencies, so here's what we're going to do instead:
Make a function generator send a 1V peak-to-peak sine wave with a 1V offset (so we don't annoy the electrolytic capacitors too much) into port P1. Then look at the output at P2 with a scope reading off Vpp at the frequency we set on the function generator.
OK, so our filter blocks pretty much everything above a few tens of Hz with the -3dB point at around 10Hz! Promising!
