Legs
A project log for Star Wars Rebels: Chopper
Chopper is a C1-10P droid from the tv show Star Wars Rebels. He's a very grumpy droid and should be a lot of fun at conventions.
kenneth-zabornyKenneth Zaborny 01/17/2016 at 16:320 Comments
After a lot of trial and error I decided to 3d print the legs. The main skeleton is a piece of 1 by 1 steel tubing so the 3d print is just a detail and not a support material. This way I was able to lower the infill and save material.
The 3d model turned into a print once I sliced it properly. My first prints had issues because the filament I was using was low quality. I ended up using them anyway with some smoothing with an ABS slurry.
After many hours of printing I was able to assemble the pieces into two functional legs.
The steel supports bolt onto the main body. This enables me to disassemble Chopper to the point where I can transport him in the smallest of vehicles. He even fits in my DeLorean.
