Center leg
A project log for Star Wars Rebels: Chopper
Chopper is a C1-10P droid from the tv show Star Wars Rebels. He's a very grumpy droid and should be a lot of fun at conventions.
kenneth-zabornyKenneth Zaborny 01/17/2016 at 16:360 Comments
Chopper's center leg isn't a footshell like R2D2 and other droids. It's just a single large wheel on a caster. The hardest part was finding a caster/wheel combination that worked. I eventually had to build a caster around a wheel that I liked. I'm testing that now. So far I've had minimal issues from the assembly.
The caster tracks properly as the droid turns. However, just moving him by hand resulted in a nasty face-plant. I'm looking at positioning the batteries to help compensate.
