Pensacon 2017
A project log for Star Wars Rebels: Chopper
Chopper is a C1-10P droid from the tv show Star Wars Rebels. He's a very grumpy droid and should be a lot of fun at conventions.
kenneth-zabornyKenneth Zaborny 03/10/2017 at 18:050 Comments
At the Rogue One premiere Chopper experienced a failure of a shoulder bolt that nearly caused a catastrophic crash. So, the entire month of January was spent beefing up the shoulder linkage and redesigning his stance to use a better center wheel. Here he is a Pensacon 2017 and everything worked perfectly.
You can see his new stance and wheel here. He glides effortlessly now and his runtime increased from 5 hours to over 8. By the end of day one he was running strong on the original set of batteries. I barely noticed any slowdown.
