Video Demo
01/20/2016 at 17:40 • 0 commentsFinal Thoughts
- This is pretty handy to have around!
- Connecting the activity light allows you to see network traffic.
- The Arduino Ethernet case is great for this application.
- I wish the Arduino Ethernet case was better made.
- I added an overkill DC voltage regulator - as I'm plugging this into $1000+ hardware right?
- Should run for a couple of days on a 9V.
- Someone should expand on this and add BlueTooth and a phone app!
- Arduino Ethernet is easy and cheap - Must make more things!
- Kris
Tight fit (jeez this case)
01/20/2016 at 07:31 • 0 commentsMaybe I was a little misled by how tiny this case is. Originally designed for the Ethernet shield, I don't think anything extra was supposed to go in. The little battery cover "looks" like a standard 9v size, but it's actually 1/4" smaller than the battery itself. I dislike not having case screws after trimming 4 of the 5 plastic posts, but it fits...
The Ethernet module is solid and tight, and I may tape the edges from having it pop open, but I'm happy how it turned out.
I'll follow-up with a demo video tomorrow!
Early action video...
01/18/2016 at 03:18 • 0 comments -
Low memory available, stability problems may occur.
01/18/2016 at 01:58 • 0 commentsThis is how you know your doing Arduino correctly! ;)
You could delete all the Serial.print lines and disable Serial.begin(9600);
This should save a bunch of memory and make for a better tomorrow... but "Global variables use 1,558 bytes (76%) of dynamic memory, leaving 490 bytes for local variables. Maximum is 2,048 bytes." seem fine to me as this is all this poor UNO will ever be asked to do.- Kris
Shorten the DHCP timeout
01/18/2016 at 01:33 • 0 commentsInside Dhcp.h, there is a response timeout constant of 60,000. I just changed it to 10,000 (10 seconds), and now timeout occurs about 12-13 seconds after a reset.
int beginWithDHCP(uint8_t *, unsigned long timeout = 10000, unsigned long responseTimeout = 4000);
};Found here: http://forum.arduino.cc/index.php?topic=105397.0 Hat-tip to jstamour802
ENC28J60 Libraries...
01/18/2016 at 01:06 • 0 commentsAfter some failed experiments, I found that the Norbert Truchsess library UIPEthernet located here: https://github.com/ntruchsess/arduino_uip is the best for those "ebay" cheap ENC28J60 brakout boards.
I used the following PIN configuration:
(4) SO - 12
(5) SI - 11
(6) SCK - 13
(7) CS - 10(9) VCC - 3.3V
(10) GND - GND
