Ranging Demo
A project log for SubPos Ranger
The SubPos Ranger allows you to accurately measure distance or obtain your position indoors for all hobbyist robotics applications.
bleckyBlecky 01/23/2016 at 11:341 Comment
Here is a demo of the ranging toolbox working an unmodified Atmel ZigBit module:
The firmware is the stock toolkit code (with mods to allow it to work on the ZigBit) with antenna diversity disabled (since there is only one antenna). More work is to be done, but the initial results look more than promising.
3835554 wrote 01/10/2024 at 02:44 point
Thank you! Can you share your example?
