L_CH_Corner_OXO_1.stlsimple cornerMicrosoft Trust UI Provider - Certificate Trust Link - 20.00 kB - 01/19/2016 at 20:35 |
LCH_sider_dolly_example.stla small example of a slider , using 5x10.1x4mm bearings.Standard Tesselated Geometry - 74.89 kB - 02/24/2016 at 10:31 |
LC_45x45_end2.stlThis is the 45deg offset for holing L ch as a rails or such for linear slides.Standard Tesselated Geometry - 6.04 kB - 02/24/2016 at 10:29 |
