Tracked Robot
Medium sized tacked robot
I've been wanting to build a robot for a while, and i've seen many very small kits or very expensive industrial grade robots. What I was looking for was to build something that was bigger than a toy maybe 12-18" in length and really durable. Another requirement is that it be able to carry a payload for future projects.
At this time the robot itself doesn't have a specific use case, i'm focusing on the core components before I start figuring out the specific tasks it will complete. Likely it will leverage OpenCV and have a 6DOF arm attached to it, or a turret.
I've been working with Joshua from tankchain.com on a chassis design and have purchased my tracks from him, he has been a pleasure to work with and I can't praise the quality of the tank treads enough.
I'll keep this project log updated with progress.
TODO:
  • Decide on the onboard computer - I'm still experimenting between some boards here, it will be easier when I decide what the robot will do. Currently I've been toying with different ideas with a Odroid-XU4, a Teensy 3.2, Raspberry Pi Zero. Some are cheaper than others to replicate but something like the Odroid will be great for doing OpenCV.
  • Choose an RC transmitter/receiver combo - This will be used to control the robot in the initial phases, as well as override anything the onboard computer is telling the robot to do.
  • Design, prototype, build the chassis
  • Obstacle detection & avoidance
  • FPV - i'd like a live video feed of what the robot is seeing, both video and sensor data for diagnostics and debugging.
  • 100 × Tank Treads tankchain.com
  • 1 × Sabertooth Dual 25A Motor Driver
  • 2 × IG32P 24VDC 265 RPM Gear Motor with Encoder
  • 1 × Kangaroo x2 motion controller
  • Tracks Received & Assembled
    Erik St. Martin01/20/2016 at 20:01 0 comments
    I've received my tracks from tankchain.com and they are even more durable and high quality than I expected. I can't wait to see them up and running.
    Chassis design is making progress, but likely i'll throw together something in the interim to play with.
View project log
