The Upduino v2 and Project IceStorm
A project log for FPGA Experiments
Log book of FPGA adventures at home
tom-verbeureTom Verbeure 03/18/2018 at 05:331 Comment
After laying on my nightstand for 3 weeks (during which my BlackIce-II board got all my attention), it's time to get a minimal design going.
The Upduino documentation on GitHub is a Word file that describes how to create a LED blink design with the Lattice iCECube2 software and how to program it with the Lattice Diamond programmer. I don't have those, but I decided to try if it works with Project IceStorm.
Of course, it does.
After the usual amount of struggling with command line options (forgetting to use `sudo` didn't help either), it was able to get a blinking LED going. The results can be found here: https://github.com/tomverbeure/upduino/tree/master/blink
Check out the Makefile for the right combination of command line parameters for the different tools.
Various notes:
Xenador77 wrote 08/28/2022 at 05:02 point
Highly recommend purchasing an Upduino V3.1, it was made by a different person/company and (from what others have said) is much better than previous iterations in terms of useability/and design. That being said I am slightly biased as
I recently worked on porting the V3.1 (it should-work™️ the same for the 3.0 and not too different than the v2.0/v2.1), everything builds/flashes without error, but for some reason, the UART doesn't show any signs of activity...
If you feel like taking a look/testing it out please let me know how it goes, I'm not out of ideas, but I am comparatively inexperienced with FPGAs so I might just be missing something obvious.
https://github.com/xenador77/litex-boards/
