Building a ultrasound phantom from breadboard components
A project log for Murgen: open source ultrasound imaging
An open-source ultrasound imaging dev kit side project
kelu124kelu124 12/18/2016 at 15:490 Comments
The objective of this session was to
Setup
The classical one. Using the pulser module, analog processing module, and a arduino-like to capture and stream the data. Piezo moved by a servo (module).
Phantom
What does it look like?
Capturing data
Script used were:
Acquiring images
Presented non scan converted
Comparing the image with the phantom
Preparing the image
I aggregated the 4 images in one image with the rebuild script which yielded
and scan converted it:
Conclusion
Next steps:
