Field Rover
Convert a ride-on lawn mower to an APM:Rover for pulling around carts, trailers, seed harvester and logs.
Repurposing an old riding lawn mower for towing a variety of equipment. The Field Rover will use a Navio+/Raspberry Pi for the autopilot. Connection to the rover will be over 3dr radio, wifi or internet stick.
Path planning for 100% field coverage in applications such as grass seed harvesting, herbicide application, and UXO surveying will be developed.
Obstacle avoidance through sonar, lidar or 3d sensor (asus xtion or microsoft kinect).
http://rover.ardupilot.com/
  1. One servo to control the throttle and choke.
  2. Servo to apply the disc brake.
  3. One linear servo is used to control the lever to the transmission
  4. the other linear servo is for disengaging the drive belt through the idler.
  5. The high torque servo is used for steering. Its connected to the pinion gear through the steering shaft.
View all 9 components
View all 3 project logs
zartajbashir wrote 05/05/2023 at 02:04 point
I would love to see any update related to your product as I am excited to use it for my project. https://sathasaudi.com/
Capt. Flatus O'Flaherty ☠ wrote 03/28/2018 at 19:22 point
Looks like you could do with my control system?
Peter McCloud wrote 02/28/2016 at 19:55 point
Just curious if you've made any further progress. I'm really interested in seeing this suceed.
Rob Shearer wrote 01/29/2016 at 23:53 point
I didn't get to the starter today but now have the transmission, idler and brake under servo control https://plus.google.com/+RobShearerCA/posts/jGTyWEZDVjZ. Will be waiting a few more weeks for the high torque steering servo.
Rob Shearer wrote 01/29/2016 at 01:56 point
hope to get the starter wired up tomorrow. Im testing things with a cheap ebay apm as i dont yet have a receiver compatible with the navio board. On the apm i think theres a dedicated relay pin (A9) plus you can assign other pins as relays in the full parameter list. So ill use A9 to trigger a 12v relay that will in turn trigger the solenoid to engage the starter.
Peter McCloud wrote 01/29/2016 at 00:39 point
This looks really cool!
Any plans to control the starter and the ignition through relays and through APM? With the engine I'm using for #Goliath - A Gas Powered Quadcopter I've got a relay board that's hardwired to a remote. I haven't done the work yet to integrate the control of those two items into the Pixhawk or the Firmware, so I'm really curious how you're going to handle it.
It's probably a good choice to use a single servo for throttle and choke. I looked at your picture of the throttle plate with the servo attached. I had removed the throttle plate on Goliath because it was heavy and I wanted to disconnect the governor. However it required adding a separate servo for the choke since the linkages were gone.
Good luck on the rest of the project, I'm looking forward to seeing how it comes together!
